Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   flywheel ring gear (https://honda-tech.com/forums/tech-misc-15/flywheel-ring-gear-1435962/)
zman Nov 15, 2005 09:17 PM
flywheel ring gear
The ring gear on my flywheel is messed up. Sometime when i start the car it just makes a funny noise and doesn't start, the starters not spinning the flywheel because the ring gear is messed up. We changed the flywheel and the problem is gone.
Now my question is can i get a new flywheel ring gear for the flywheel. Its a lightened flywheel and i want to be able to use it again. Where would i get this flywheel ring gear? Approximate price?
NJIN BUILDR Nov 16, 2005 04:37 AM
Re: flywheel ring gear (zman)
Honda doesn't sell replacement ring gears for their stock flywheels.If its an aftermarket flywheel with a separate ring gear you should be able to get one.Give the manufacturer a call and they can tell you the price.
Glenn
