Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   first start on fresh rebuilt engine (https://honda-tech.com/forums/tech-misc-15/first-start-fresh-rebuilt-engine-2904586/)
horn12007 Mar 1, 2011 04:43 PM
Alright first off I'm going to assume that the first start is always the most difficult start of a fresh rebuilt motor.
Anyways my lsvtec is complete other than the first start. It is boosted and has 440 injectors so on my hondata I went with the closest set up for a base map. Just put brand new plugs in it. It is getting spark and fuel.....its so damn close to starting. Its trying to run, but just won't start. It keeps on hitting and is so damn close.
also there are 2 trouble codes water temp and electrical load detected, I don't think they would be giving me any hassle.
Is there a trick on the first start? Sure hope so. lol. or any thing I should look at? any help or input to get my baby running would be greatly appreciated. thanks
Yerboogieman Mar 1, 2011 08:14 PM
Re: first start on fresh rebuilt engine
Check your fluids and grounds. Did you happen to flood it also?
horn12007 Mar 1, 2011 09:47 PM
fluids should be good......I will double check grounds and don't think it should be flooded.
::ek-4:: Mar 2, 2011 12:56 PM
What distributor are you running?
horn12007 Mar 2, 2011 03:56 PM
stock obd1 off gsr. it does have spark though.
CleanLikeJdm Mar 3, 2011 06:56 AM
Double check your timing on the belt.
slobalt77 Mar 3, 2011 07:18 AM
you happen to have the firing order wrong? only wondering since you said its trying to start, but wont stay running.
horn12007 Mar 3, 2011 05:50 PM
firing order is right. I forgot about double checking the belt.
I think the dtc 6 coolant temperature sensor is messing it up.
PyroProblem Mar 3, 2011 06:00 PM
On a stock ecu, whenever a fault code is thrown for a sensor, the ecu will substitute default values so the car should be able to run still. Usually these default values are very "safe" (rich)...Im not sure how this logic works with aftermarket tuning systems...
Id look at that coolant temp sensor fault first...
Compression numbers OK?
horn12007 Mar 3, 2011 09:07 PM
yea they are good.
as for the cts. I ran wires to the temps sensor and to d13 and d22 and same thing. I then swapped it out for another used cts and the same.
I have the air fuel mix gage and it shows very rich as I'm cranking.....so idk.
killacam661 Mar 7, 2011 01:15 PM
did the car run before?
horn12007 Mar 8, 2011 11:54 AM
back when it had a different block. The head on up ran before. I got the block and fully rebuilt it. The old block had cracked sleeves.
