First B18 EK project
Hi guys I'm new to the Honda world and currently building my own. I was wondering if anyone had pics or part number of the OEM engine mounts I would need for a B18A1 swap in a 97 cx. Also if Ebay radiator hose kits would fit the stock (97 civic cx) radiator I have. thamks!
this is for the hose kit http://www.ebay.ca/itm/350662681086?...84.m1423.l2648 |
Re: First B18 EK project
http://www.hasport.com
http://samcosport.com Both websites have all the parts you need for your swap, I understand they are pricey but anything worth doing is worth doing right. If you insist on using used parts try ebay for the used hasport mounts (not something I would do personally) or if you were trying to use OEM you would want the mounts from a 99-2000 SI. Again, I stress anything worth doing is worth doing right. I've personally used the swap parts from both companies on my B18A CRX (along with the HasPort shift linkage). Good Luck. |
Find yourself EM1 rear and drivers side mounts.
Bigger challenge is going to be wiring: https://honda-tech.com/forums/hybrid-engine-swaps-18/gathering-ek-wiring-information-558245/ You can use the stock radiator, but you need Integra hoses and they're larger than than the Civic inlet/outlet. Just be sure to re-tighten after warm-up and continually check them. |
| All times are GMT -8. The time now is 01:56 AM. |
