Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   exhaust temp meter (https://honda-tech.com/forums/tech-misc-15/exhaust-temp-meter-996637/)
skunk2powered Sep 19, 2004 11:07 PM
exhaust temp meter
what does this meter tell you? what is the benifit of knowing your exhaust temp? thnks.
skunk2powered Sep 20, 2004 03:35 PM
bump
thumbtack Sep 20, 2004 06:00 PM
Re: exhaust temp meter (skunk2powered)
You can use it to tell if your running lean or not. If your running leaner... your exhaust temps rise.
sol_guy8569 Sep 20, 2004 06:00 PM
Re: (skunk2powered)
Mainly the pirommeter is used in turbo cars it tells you what your exahaust temperature is either before the turbo or after. Because the cooler and more dense the air the more power you will get.
skunk2powered Sep 22, 2004 06:46 PM
thnks
