Exhaust material properties
I've been talking with someone about thermal conductivity of material in car exhaust system. If you compare the aluminium to the stainless steel, the aluminium has around 200 W/m.K and stainless steel is around 20 W/m.K.
I think the aluminium pipe will lose more heat to the surrouding, resulting in a decrease of internal temperature as opposed to the stainless steel...is this right? |
Re: Exhaust material properties
Internal temperature of what?
Originally Posted by grumblemarc
(Post 46717000)
Yes, but it's not going to be a night and day difference.
Also aluminum has 2 distinct advantages to steel. it weighs less and it will not rust. BUT it will crack before it bends and will need to be mig welded i believe. sorry if thats wrong but i call a mig a tig and a tig a mig all damn day long. Im sure theres a reason why we dont use aluminum though i just dont know why...
i thought of it probably because it gets hot and aluminum becomes kind of maliable and brittle.
Originally Posted by mike703
(Post 46728297)
I guess I have to ask, in the the real world, what difference does it make?
I think aluminum sounds like shit that's why its not used from the manufacture. And its exspensive.
Originally Posted by mhax
(Post 46729608)
Yeah but aluminium can dissipate heat way better than stainless steel, so stainless steel will get hotter. So i don't think the aluminium will get to the temperature where it gets maliable and brittle.
closer to the engine, the manifold.. could get hot enough to deform and likely blow out. Also aluminum doesn't rust but it does "oxidize." it can also be susceptible to some of the more corrosive components of exhaust, especially in the presence of moisture. if you want to do better than stainless, Ti or Iconel. both high dollar but totally up to the task. |
(Post 46729834)
| All times are GMT -8. The time now is 01:08 PM. |
