Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Engine Light came on for the first time. WTF (https://honda-tech.com/forums/tech-misc-15/engine-light-came-first-time-wtf-122513/)
fcuked Jan 31, 2002 06:34 PM
Ok i have had this problem for a while, my car tends to sputter, i don't think it's getting enough fuel, i changed the fuel filter but that didn't help much. My car usually sputters like this when i approach an oil change. Basically it starts chocking and slowing down even i floor it. To fix it i have to keep it floored and then it clears up and goes, then after a while at low rpm's it does it again. So anyway long story short i worked on my car, then hosed down the engine bay lightly before i left, and i think i got water on my short ram intake. Anyway when i turned on the car i heard a whistling sound (i think water was going in the intake) and then i just drove out, the car started sputtering and then at one point to clear it up i floored it again, so as i did it cleared up and the engine light came on. I turned off the car came out and there was a slight burning smell, then i turned the car back on and the engine light came back on after 20 seconds approx. What could this be????
[Modified by 1.8 HB, 3:35 AM 2/1/2002]
fcuked Feb 1, 2002 03:26 AM
Re: Engine Light came on for the first time. WTF (1.8 HB)
ttt
88_SC_CRX_Si Feb 1, 2002 06:45 AM
Have you checked your ECU to see what code it's flashing... That well help give you some idea of what is happening.
I get the impression your running too rich, and it's loading/fouling up/out on you. Thats why you have to floor it, to blow it out.
ntensehonda Feb 1, 2002 10:54 AM
Re: Engine Light came on for the first time. WTF (88_SC_CRX_Si)
I agree, your short ram will dry out. Are you seeing any smoke comming out if it?
