Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   engine dampner (https://honda-tech.com/forums/tech-misc-15/engine-dampner-879926/)
h22 civic May 29, 2004 05:35 PM
engine dampner
any one using one of these they go from the engine block to the engine mount kind of like a shock
mmuller May 29, 2004 05:46 PM
Re: engine dampner (h22 civic)
they are more for madzz JdM StYLlz points rather than function( meaning they dont do chit)
h22 civic May 30, 2004 06:04 PM
Re: engine dampner (mmuller)
http://images.honda-tech.com/set1//smile/emcrook.gif how could it not do anything ??
h22 civic May 31, 2004 11:02 AM
Kal May 31, 2004 11:03 AM
It's better to get ES MM inserts. they work better than an engine damper does, but if you use them in conjunction your engine will not move at all much.
h22 civic May 31, 2004 11:38 AM
Re: engine dampner (Kal)
i got place full race mounts and leave on a 26" slick at 7200 with no hood on the car to see how bad it moves the motor, and the motor moves a little im trying to stop the move ment will these dampers help at all all feed back is welcome but prefer people who used them
Eddiebx May 31, 2004 02:21 PM
if u want zero movement, ur gonna have tog et urself solid metal mounts or something
