Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Engine build (https://honda-tech.com/forums/tech-misc-15/engine-build-2224040/)
mskansan Feb 12, 2008 09:18 PM
Engine build
Well nothing new building an LS motor and I have a question for the professional engine builders out there, I myself have fully built a 350 v8 ( build meaning micrometer everything on the engine, crank, pistons, valves, cylinders, and including timing the camshaft). I want to know would it be ok to measure the cylinder with a cylinder bore type measuring tool or using the telescoping t-gauge, where you would have to micrometer the gauge after removing from cylinder. Reason being I dont want to spend an extra 200 dollars on a decent set of telescoping gauges that i'll use once in a blue moon.
slowcivic2k Feb 13, 2008 05:05 PM
Re: Engine build (mskansan)
I would highly suggest at least an inside micromoeter to get anything accurate. If you went this route, you will have to check the bore at several positions, and axes it ensure the bore is not tapered or out of round.
T-gauges can work just fine as long as they are level and capable of holding the measurement without moving.
mskansan Feb 14, 2008 08:51 AM
This what I thought, but I wanted to make sure this was a good way to measure. I dont want to spend money on tools I dont need. thanks
Crazydave Feb 14, 2008 10:11 AM
Re: (mskansan)
Have you though about having a shop "mic" them for you?
