sir swap in civic 94hb b18 Help please!
hi! i just bought a 94 civic hb with an acura b18 in it.
i also own an sir engine. my question is will all the b18 harness plugs fit on an sir and his computer? cuz i cant find any sir harness...
help please
help please
Re: sir swap in civic 94hb b18 Help please!
your b18 is probably obd1 unless your car is converted to obd2 which doesn't seem very likely. If you reuse the obd1 stuff you'll just need a new ECU, as I'm assuming your b18 is a b18a/b? Also the vtec wiring if you're going from a non-vtec..
Technical Hero
Reuse your obd1 injectors and alternator. Also you'll need a distributor adapter for the obd2 ecu or swap the b18 internals into it. You'll also need to wire up VTEC and knock as well as run your IAT into the intake arm as the obd2 b16a doesn't have it on the intake manifold.
