Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   ECU testing? (https://honda-tech.com/forums/tech-misc-15/ecu-testing-2973758/)
bendrums87 Aug 28, 2011 08:55 PM
ECU testing?
Does anyone know of a way to test an ECU? I bought a car without a motor but I am swapping the motor and want to sell the old ECU from the car but I don't have anyway of testing it on the car as of now..
The car is a 93 Del Sol
civickiller Aug 28, 2011 09:22 PM
Re: ECU testing?
any friends car u can test it on ?
bendrums87 Aug 28, 2011 09:40 PM
Re: ECU testing?
didn't think about that but I don't know anyone with a del sol
civickiller Aug 28, 2011 10:28 PM
Re: ECU testing?
what ecu is it?
bendrums87 Aug 28, 2011 10:52 PM
Re: ECU testing?
It was the stock ecu in a 93 del sol si auto... other than that I don't know off hand or what markings on it indicate what ecu it is
mouab18c1 Aug 28, 2011 11:14 PM
Re: ECU testing?
What do you need to test the ecu for?
bendrums87 Aug 28, 2011 11:44 PM
Re: ECU testing?
I just want to see if there's anything wrong with it... if it's good then I was going to sell it
civickiller Aug 29, 2011 04:15 AM
Re: ECU testing?
so its xxxxx-p28-axx last 2 numbers has a 5 in it somewhere?
im not sure about running auto ecus in manual car, auto ecu codes?
ideally it would need to be test in a auto sohc v d16z6, like eg auto ex
maybe someone could chip in on running auto ecu's in manual cars, i mean there is always converting it to manual but idk if ud want to do that
mouab18c1 Aug 29, 2011 10:08 AM
Re: ECU testing?
It's fine testing out an auto ecu in a manual car. You'll just throw the CEL for the auto something. Won't hurt anything.
bendrums87 Aug 29, 2011 08:20 PM
Re: ECU testing?
so basically if it gets plugged into a d16z6 motor and it actually starts and doesn't throw any codes it should be good? sorry i'm not very experienced on the technical side of ECU's and all... haha anything else mechanically I am fine on but electronics are another ballgame...
civickiller Aug 29, 2011 08:39 PM
Re: ECU testing?
if it starts, it will throw the auto sensor code. if thats the only codes then it should be no problem converted to manual. the only thing you might not know is if the automatic circuitry works. but most people who would buy it will convert it to manual anyways
mouab18c1 Aug 29, 2011 09:55 PM
Re: ECU testing?
Throwing a CEL will be normal. As long as it's not a solid CEL then the ecu is working properly.
bendrums87 Aug 30, 2011 07:45 PM
Re: ECU testing?
ok thanks for all the input I will start doing some digging then
