Ecu safe mode
how can you tell if the ecu goes into safe mode
Re: Ecu safe mode
The Check Engine Light / Malfunction Indicator Light will normally come on. In the case of a PM6 OBD0 ECU, IIRC, there is a red light on the ECU itself that will come one or flash. It will flash in a specific sequence. This sequence of flashes will tell you what problems the ECU is encountering.
ECU light flashing sequence. SHORT flashes are single digits (1/2 second) LONG flashes are 10's (1 second) You may have multiple codes, if there are multiple codes there will be a slight pause between the sets of code flashes. Ex short...short...short Pause long...long...short...short...short In this example you would have a code 3 & 23. Once you have figured out the numbers that your ECU is flashing you need to check them with a list of diagnostic codes. Click here for a list of OBD diagnostic trouble codes. |
| All times are GMT -8. The time now is 09:02 AM. |
