Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Dyno Q's (https://honda-tech.com/forums/tech-misc-15/dyno-qs-241016/)
SoulSurfer Jul 28, 2002 10:34 PM
Dyno Q's
Im looking at the Crower dyno for their LS cam #62403 and #62404. They say the RPM range is 1,000-8,000 for the #62403 and 1,100-8,200 for the #62404. However, when I look at the dyno, their max RPM is 7k on the #62404 and 7,500 on the #62503.
Can anyone explain to me why it's not run up to 8k?
Kamin Jul 28, 2002 10:35 PM
Re: Dyno Q's (LSDelSol)
because there retarded?
maybe they didnt have the valvetrain setup. (dont ask me why..)
or maybe the cam makes the most power before 7000.
SoulSurfer Jul 30, 2002 02:10 PM
Re: Dyno Q's (KAMiN)
Anyone have these cams and know if this is the case?
non-VTEC Jul 30, 2002 03:40 PM
i have 403's and they make peak power just under 7000rpm. the 404s make peak power just over 7000rpm.
the reason they say you can rev to 8k+ is because the torque band still pulls up to that rpm range.............
even though they dont make peak power up that high they sure do pull pretty good up there http://images.zeroforum.com/smile/emthup.gif
StorminMatt Jul 30, 2002 05:18 PM
The reason why their dynos don't go up to 8000RPM is quite simple. A stock B18B can't rev that high without blowing up. You would need to upgrade virtually every moving part in that motor to safely rev that high. Also, the rev limit on a B18B ECU is 6800RPM. I find it interesting that they are able to rev above 6800RPM with the 62403 without a modified ECU. Or did they just fail to mention any ECU mods? I also find it most interesting that their more aggressive cam lost less low end and midrange power.
[Modified by StorminMatt, 2:36 AM 7/31/2002]
SoulSurfer Jul 30, 2002 07:48 PM
Re: Dyno Q's (StorminMatt)
ECU mods were mentioned on the dyno sheet...
Non-VTEC: what do you shift at when racing?
non-VTEC Jul 31, 2002 03:07 AM
8000rpm in 1'st.......about 7800 in 2'nd and about 7600 in 3'rd etc.......
SoulSurfer Aug 5, 2002 02:24 AM
Re: Dyno Q's (non-VTEC)
Thanks...so with Ferrea valves, springs, port and polihs, etc, you think its a good investment?
[Modified by LSDelSol, 8:25 PM 8/5/2002]
