Driveshaft question
I have a 93 YS1 tranny and obviously need 93 Ls driveshafts and a halfshaft. But what do the driveshafts and halfshaft look like? Are the driveshafts male/female and the halfshaft male/female? I need to know the configuration, thanks.
Re: Driveshaft question (85mm LS VTEC)
pass side would be male/male, the driver side would be female/male if i remember correctly. the half shaft will be male/male.
Re: Driveshaft question (RABHonda)
no, drivers side is male to male, half shaft is female to male, thats how they are on my teg axles
Re: Driveshaft question (civickiller)
What year is your Integra?
idk i bought this from a friend who had it in a crx, with cable tranny. but that drivers side being male/female and the half shaft being male/male is more like a hydro tranny axle setup, not the cable ones
call up a parts store and ask them or go look at one at a parts store and then youll find out, but im pretty sure the way RAB said is for hydro trannys not cable |
yeah. im thinkin im correct for the driveshafts concerning a hydro tranny, but i dont know why they would change within the year depending on the tranny.
as far as i know all cable trannys used male/male axles with half shaft being female/male. well trannys that used half shafts
| All times are GMT -8. The time now is 07:00 AM. |
