does anyone know why honda designed motors like this?
does anyone know why on honda motors they put the oil filters on sidewards...so whenever you change the filter you get a sheet load of oil that comes spilling on your arm?? instead of a straight up design so it doesnt spill!
http://www.findingnew.com/wp-content...011/04/111.jpg
Re: does anyone know why honda designed motors like this?
hah probably because when they built the motor they have to install an oil filter before they fill it with oil
It still spills when it's straight up and down, just not as much. And, it spills out from the entire circumference....the 2007+ CR-V's are straight up and down and I could never change one without it spilling a little on me arm.
The easiest oil changes are the 2006+ Civics because they're on a slight angle and the oil only spills out predictably in a small stream from one area of the flange.
With the carcinogenic potential of lubricants, I would try to minimize repeat exposures. Wear gloves as PPE.
Resident Gearhead
Because an immaculate design is almost impossible to achieve. There will always be
compromises.
That said, I think D, B, F and H series engines are engineering marvels. For the most
part, these motors are a dream to work on compared to a lot of other makes.
Also, it's possible to avoid getting oil on yourself when removing the filter.
compromises.
