DIY: How to convert an obd1 automatic ecu to manual
15 Attachment(s)
This is a simple DIY for people who want/need to convert their own automatic ecu into a manual instead of buying a new one. I highly recommend that you get some soldering/desoldering practice before attempting it by yourself.
List of things you need: obd1 automatic ecu Attachment 452120 Philips Screw driver Attachment 452121 Soldering pin http://i23.photobucket.com/albums/b3...a/IMG_0335.jpg desoldering braid http://i23.photobucket.com/albums/b3...a/IMG_0331.jpg soldering wire http://i23.photobucket.com/albums/b3...a/IMG_0332.jpg Wire cutter http://i23.photobucket.com/albums/b3...a/IMG_0333.jpg Carb cleaner; The carb cleaner is used to clean off the clear coat that Honda used to protect the circuit boards. You can either use a tooth brush and brush off the clear coat before you start doing any sort of soldering or you can use it to clean it off afterwards. I however did not have any with me at the time so please forgive the sloppyness of the clear coat burns. Any ohm resistor since you'll be cutting off the end pieces to use. First and most simple get your ecu and take off both back and front covers: Attachment 452122 On the front side locate RP17 and RP18: Attachment 452123 Once you have located them turn it to the backside and get your soldering pin and desoldering wire. I usually like to heat up the desoldering braid to make things easier: http://i23.photobucket.com/albums/b3...a/IMG_0308.jpg Again locating RP18 and RP17 on the back of the board start desoldering the resistors out. " You could either cut them out first and then desolder it or desolder it first and then pull them out" I however chose to desolder them both before pulling anything out. Attachment 452124 This is how it should look like once you have desoldered it: Attachment 452125 Do this to all the connecting spots in order to take the resistors out. Now that you have desoldered all the connecting spots you should be able to pull them out easily with your wire cutters or pliers: Attachment 452126 Attachment 452127 Now we will fill up the holes for RP17 "If you chose to cut the resistors out before desoldering than you can skip this step. Here is a pic of RP17 filled: Attachment 452128 Now take your resistor and cut off one of the end wires to use for RP18: Attachment 452129 Take that piece and bend it into a U shape for easy insertion into the ecu "RP18": Attachment 452130 Once you have inserted it into RP18, turn the ecu over and bend the wires so that it stays in place. This also makes the soldering much easier: Attachment 452131 Now solder it in. Should look like this: Attachment 452132 Then take your wire cutters and cut off the extra ends that are sticking out: Attachment 452133 This is how it should look like once you do everything: Attachment 452134 Once you are done make sure you double check to see that all soldering joints looks nice and clean. When you plug in the ecu into the car make the the battery is disconnected before doing so. I hope this will help out others who are in need of it. Goodluck!!!!!!!!!!! |
Re: DIY: How to convert an obd1 automatic ecu to manual
Thanks a lot! This is great and it should be very helpful to everyone out there seeking help on this conversion.
two thumbs up to you man! |
Thanks, I hope it helped with your situation.
Nice:thumbup:
saved to .doc
Thank you |
What size resistor did you use when you cut the one end of it off for RP18?
Just finished my onversion and all IS good! Thanks again Mouab18c1!
There is no resistor needed. Just cut off a leg from one of your resistors and use that.
You're welcome |
its just a jumper needed for rp18
ive never cleaned the board before and just cleared away any solder after i put the ecu between 2 books and just melted the back then pulled the resistor with a needle nose pliers, then if it wasnt clean enough, just sucked out the solder but thats just me. good write up though |
Cleaning the clear coat off just makes it look better. It also makes it easier to solder.
So I need some input. I am trying to verify if my ECU is auto or manual. It is a OBD1 PR3 from a JDM Integra XSI. The ECI # is 37820-PR3-J51, which decodes as an automatic from everything I have seen. However, there is NO resistor on RP17, and it looks like it came that way from the factory.
Bump, nice write up
Cool will this guide apply to the P12 ECU in the 92' 96' prelude?
Bump. Nice thread. My question is will this go with all obd1 ecu? For example p06?
Originally Posted by danielolaguez92
(Post 49075974)
I have a question though, my ECU was chipped in the past and the guy who sold me it didn't know anything about it. It has the rp17 and rp18 resistors on the board, am I right to think if it has these resistors it was an auto ecu? |
bump cause no one answered my question
Originally Posted by redturbo0
(Post 49215643)
I believe so, yes...
Nice :thumbup:
could you just use a paper clip for the jumper? I mean it works for everything else to jump.
Nice.
I kno this is an old thread but will this work for an OBD2B auto?? I jus converted my 2001 integra to manual and was wondering if this also applied to it as well. Help!!
Originally Posted by ralfsdc2
(Post 49691832)
