DIY 5 lug ?
Looking for the DIY 5 lug article...
Make you're own 5 lug using blah & blah for parts & reuse you're trailing arm blah blah..
Re: (mtber)
i wonder if you can replace just the spindle, keep your stock brakes and whatnot just to switch the lug pattern to 5 lug. anyone know the spline and the size of the axle nut for this application? and if its cross compatible with civic and integra axles?
Re: (phantom_sol)
I'm bringing this one back up.
If you ordered new bearings and hubs for a US spec ITR, you could put this in a non-itr steering knuckle and rear trailing arms? Spline and axle nuts are the same right? Modified by jg at 5:37 PM 1/4/2004 |
Re: (jg)
anyone know if you could use an itr or crv spindle/hub in an integra knuckle?
is there any 5 lug spindle or hub that uses the same spline of a 4 lug integra? |
Re: (phantom_sol)
We're asking sort of the same question. The itr is the same spline size. I have ITR axles in my '98 'teg GS/GSR steering knuckles. I just don't know if the size/o.d. of the bearing/hub is bigger, or something, that may prevent it from being pressed into the normal 'teg steering knuckles...?
Anyone know this one? OR, does anyone have access to both parts? |
Re: (jg)
anyone?...
| All times are GMT -8. The time now is 03:29 AM. |
