Distributor Cap for external coil
I was told that you can use a Honda accord distributor cap on an integra distributor if you are running an external coil pack. Anyone try this? Both caps look very similar.
Here is the accord cap http://contentinfo.autozone.com/znet...78/14/image/4/ Here is the Integra cap. http://contentinfo.autozone.com/znet...82/14/image/4/ |
Re: Distributor Cap for external coil
yes it's true....i have used those in the past..
Originally Posted by non-VTEC
(Post 47040533)
1 Attachment(s)
Originally Posted by CaliforniaDad
(Post 47040566)
That's good to know, Because I just spent 50+ bucks for the MSD modified cap for the integra, because I'm using the MSD external coil pack. And the MSD cap didn't fit very well. The holes on the MSD cap didnt line up very well to the holes on my distributor housing. So next time I need a cap I can just use an OEM accord cap. Cheaper than the MSD
Attachment 262147 Are you sure you have the correct cap? What is MM&Y of car/engine? 94 |
Originally Posted by fcm
(Post 47043758)
That's odd, I have the MSD cap and the MSD Blaster coil, and my MSD cap fits perfectly...
Attachment 262147 Are you sure you have the correct cap? What is MM&Y of car/engine? 94 http://www.summitracing.com/parts/MS...n/?prefilter=0 |
Do you have the stock distributor, [TEC]?
If so, I would have returned the cap, there is a defect in it. 94 |
Its a new distributor I just got off ebay.
http://www.ebay.com/itm/1996-2001-Ac...7da614&vxp=mtr |
So not OEM, maybe that is the problem? 94
yeah I don't know might be.
I cant open link on phone but did you check the persons feedback and make sure they werent located in hong kong? Anything, I mean everything ive ever order from anyone from hong kong never worked or broke within a day or two. Mainly electronic stuff and a distributer is an electronic device as well.
Originally Posted by 91DxVTEC
(Post 47046447)
| All times are GMT -8. The time now is 06:54 AM. |
