Differences between engine series?
Im new to Hondas, and im just wondering what the differences are between the engine series? For example, what sets the K series apart from B series engines? I was hoping you guys could enlighten me, or point me to a website or something.
You're going to have to do a lot of research. There isn't just a couple of things that make them different, every aspect of the engines are different. The K series uses a more advanced VTEC system, is mounted backwards from the B series, has different internal dimensions, different cam profiles, different flow rates for the head, different everything. Like I said earlier, do some research on both engine series and then compare notes.
Re: Differences between engine series? (toxin813)
Re: Differences between engine series? (8200RPM)
they have different names https://honda-tech.com/forums/images...s/emsmilep.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM »</TD></TR><TR><TD CLASS="quote">http://www.jdmuniverse.com/for...0Info
voila! hope that helps</TD></TR></TABLE> I noticed some errors on that site, do some additional research to get everything square. |
Re: Differences between engine series? (Kendall)
yes, there are errors here and there. just like any other site will most likely have. but its a good start and covers alot.
| All times are GMT -8. The time now is 03:48 AM. |
