OBD2a to OBD1 P72 Jumper harness w/ missing pins
Old 12-13-2010, 03:29 AM
Unomi's Avatar
Default OBD2a to OBD1 P72 Jumper harness w/ missing pins
As of late, I've been fighting my car
1997 Civic DX
1993 B18C1 engine
OBD1 ECU w/ jumper harness to OBD2a Civic DX
I took the ECU out and traced the pinouts and noticed a couple wires not there. On connector A, I'm missing
11. EGR - Exhaust Gas Recirculation solenoid valve
22. ICM - Ignition ControlModule
Does this pose a problem?
Old 12-13-2010, 04:18 AM
kyden's Avatar
Default Re: OBD2a to OBD1 P72 Jumper harness w/ missing pins
you don't have egr, so thats not needed.
icm should be there though.
Old 12-14-2010, 01:02 AM
Unomi's Avatar
If you don't mind me asking, where should this be linked in the DX harness?
Also, thanks for the quick response.
Old 12-14-2010, 01:31 AM
Technical Hero
HondaPartsHero's Avatar
A20 I believe
http://www.ff-squad.com/technet/wiring.obd2a.htm
Old 12-15-2010, 02:19 AM
Unomi's Avatar
Awesome! Thanks for the link. I need to do more research on FF-squad. That's the place I used to find the OBD1 P72 pinout.
To follow up, it looks as though loose wiring is my problem. The previous owner did a poor job. after placing the ECU back in and securing it, the codes went away without any troubleshooting. I'll keep the thread alive for a tad while I continue to fix/improve, just in case someone else is having similar issues. I'll post pics is requested.
Again, thanks again for the quick responses!
moaterboaink1ng
10-15-2012 01:28 PM
Patrickchampagne2006
03-29-2007 04:57 PM
i3oricua
05-24-2003 12:20 AM
Quick Reply: OBD2a to OBD1 P72 Jumper harness w/ missing pins
