Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   difference between 02 sensors... (https://honda-tech.com/forums/tech-misc-15/difference-between-02-sensors-206123/)
Kevin Jun 11, 2002 12:23 PM
What is the difference between the front and rear 02 sensors besides the plug? Could you cut the plug off of one of the rears and use the sensor on the front?
car = 00 Civic Si turbo
[Modified by 5speedv6, 9:24 PM 6/11/2002]
minime Jun 11, 2002 04:12 PM
Re: difference between 02 sensors... (5speedv6)
the sensors should be the same. but the wires are shielded so you will probally run into problems if you try to splice them together
