Is there a write-up on how to change heater core without removing whole dash??(99 ek)
I know how to take my dash off but I herd there's a way to do it with out removing the whole dash..Plz post a link to write up if there's one..Thanks in advance...
Old Fart
Re: Is there a write-up on how to change heater core without removing whole dash??(99
That would be a neat trick, but it's not going to happen, the heater core is inside the heater box, the box needs to be "split open" to remove the core, you also have to remove the heater box to split it... http://www.hondaautomotiveparts.com/...y5=HEATER+UNIT. 94
^^^^Thanks for the info but I guess I mean how to change the whole heater box with out removing the dash..Is that possible???
Old Fart
That depends on what you mean by not pulling the dash off.
You would still have to loosen the dash and tilt it up enough to pull the heater box back far enough to heater core connection tubes can be pulled inside the firewall so box will slide down and out, it's hardly any more work to just pull the dash out of the car and get it right out of the way.
You can drop the steering column. loosen dash, undo any wiring connection on the pass. side and lift the pass. side of dash and hang it with wire, [we use bailing wire] around the sun visor mount that will keep it out of the way so you can pull the heater box. 94
ella94
18
04-02-2006 08:47 AM
