Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   datalogging not working? (https://honda-tech.com/forums/tech-misc-15/datalogging-not-working-1678921/)
TehMan Jul 3, 2006 06:51 PM
i'm using a p06 ecu
ok we have the pins in the ecu...and plugged the xenocron datalogging cable into it and into the laptop...we cut j12...we've tried to run freelog and uberdata....we thing on the cable flickers a green light but we're not getting any response from the laptop...what could be the problem?
JDM_Ej Jul 3, 2006 07:02 PM
Re: datalogging not working? (TehMan)
Could be anything man. I'm trying to do the same thing using ECU Control and Crome.
Did you install the datalogging plugin on your ROM?
The support for DIY ECU modifications SUCKS... trial and error unfortunatly. https://honda-tech.com/forums/images...es/emdgust.gif
TehMan Jul 3, 2006 07:09 PM
Re: datalogging not working? (JDM_Ej)
i hooked the cable into the laptop and it said new hardware and we installed it onto the laptop...
am i suppose to just cut one side of j12 or remove it completely?
TehMan Jul 3, 2006 08:17 PM
well it datalogs on uberdata for just a second and then it stops...and it will log and then it won't...i dunno whats wrong with it...i checked the solder connections and they are nice and strong...https://honda-tech.com/forums/images/smilies/emsad.gif
TehMan Jul 4, 2006 05:02 PM
so i'm guessing noone on this site knows how to do this?
JDM_Ej Jul 4, 2006 11:25 PM
No one ever answers in here. I would PM Kenji if you want some help. https://honda-tech.com/forums/images/smilies/emthup.gif
mtber Jul 5, 2006 01:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">well it datalogs on uberdata for just a second and then it stops...and it will log and then it won't...i dunno whats wrong with it...i checked the solder connections and they are nice and strong...https://honda-tech.com/forums/images/smilies/emsad.gif</TD></TR></TABLE>
Uberdata requires j12, I do not recommend ubderdata.
1. Make sure quick datalog + rtp is installed onto the eprom/ecu you are trying to log with.
2. Make sure j12 is removed
3. Make sure your datalogging cable is pined out properly
4. Make sure your port settings in crome/laptop/serial cable are setup properly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">No one ever answers in here. I would PM Kenji if you want some help. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Good luck with that https://honda-tech.com/forums/images...s/emsmilep.gif
ylfotevoli Jul 5, 2006 03:47 AM
Re: datalogging not working? (mtber)
http://www.hondata.com https://honda-tech.com/forums/images/smilies/emthup.gif
