Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   CTR Cams Set up (https://honda-tech.com/forums/tech-misc-15/ctr-cams-set-up-1023489/)
gamakichi77 Oct 14, 2004 05:28 PM
CTR Cams Set up
now i'm using B16A engine with CTR cams and stock valvetrain.......after install the CTR cams, vtec sounds so great and noisy.........but after i sets it to 1/2 degree advanced fot both intake and exahusts, power is drop...............
is there any good sets up for CTR cams on stock engine?..............with vtec sounds noisy also..............
thanks.
irev210 Oct 14, 2004 05:37 PM
Re: CTR Cams Set up (acidburns_di)
you are going to need to put it on a real dyno... dont just go by your butt dyno
gamakichi77 Oct 14, 2004 05:53 PM
Re: CTR Cams Set up (irev210)
thats the problem man.....we doesn't have any dyno machine here...............any helps will be much appreciated.......
