Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Crank pully bolt (https://honda-tech.com/forums/tech-misc-15/crank-pully-bolt-1222011/)
CRXified Apr 22, 2005 11:02 AM
Crank pully bolt
im worried about breaking mine off cause its being a bitch to break loose. it probably was never off before (just got JDM b16 Sir 2 swap) and i heard heating it can cause shit to go wrong and damage the bearings and warp the crank pully. is this true?
mrDFWmechanic Apr 22, 2005 11:28 AM
just put an allen wrench between the flywheel and block and get a long ass breaker bar and just have someone hold the motor while somebody else stands on the breaker bar. thats how i got mine loose.
JDM_Ej Apr 22, 2005 12:45 PM
Re: (iROCKtheSOHC)
Or air tools.. ive gotten mine off a few times this way.
msmotorsports Apr 22, 2005 02:36 PM
Re: Crank pully bolt (CRXified)
If this has never been taken off before you won't get it off with an air hammer. You will need the tool specialy made for this job. It is a hex head that is hollow in the center with a long breaker bar attatched to it so you can get a socket on the bolt. Moroso and Snap on makes them. I'm sure other companies do as well but can't think of any right now.
CRXified Apr 26, 2005 06:48 AM
Re: Crank pully bolt (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">If this has never been taken off before you won't get it off with an air hammer. You will need the tool specialy made for this job. It is a hex head that is hollow in the center with a long breaker bar attatched to it so you can get a socket on the bolt. Moroso and Snap on makes them. I'm sure other companies do as well but can't think of any right now.</TD></TR></TABLE>
borrowed 1 from the local honda dealership, came off in 2 mins with it lol
thanks
Audi RS4 Apr 26, 2005 07:11 AM
i had to break down and buy the $200 impact wrench from sears to get mine off. The two parts that make me swear the most the carnk pulley bolt and the bitch pin in the shift linkage at the tranny..... https://honda-tech.com/forums/images...s/emthdown.gif
Crazydave Apr 26, 2005 09:11 AM
Re: Crank pully bolt (Carparts-Auction.com)
I've never had a problem removing a crank pully bolt with and air gun.
you just have to make sure that you have enough PSI
