Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Constant CEL with no code????? (https://honda-tech.com/forums/tech-misc-15/constant-cel-no-code-1548156/)
THEUSED Mar 4, 2006 06:28 PM
So heres the deal ive been driving my car for about a week now and it had been running fine mild built gsr, Hondata s200 p28, but yesterday the cel came on and it wouldnt rev over 4k and its idleing at 2k(I dont think that has anything to do with my question but anywyas) and when I jump the service connector it doesnt blink at all, i threw in my stock cx ecu and the cel doesnt come on with that one at all, so I have no idea whats going on, has my ecu went bad?
THEUSED Mar 5, 2006 03:29 PM
Re: Constant CEL with no code????? (THEUSED)
Up, I need my VTEC https://honda-tech.com/forums/images...s/emsmilep.gif
SilCiv2K Mar 5, 2006 03:57 PM
constant cell is usually a symptom of a bad ecu, try another ecu.
crapanese Mar 6, 2006 12:47 PM
Re: Constant CEL with no code????? (SilCiv2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilCiv2K &raquo;</TD></TR><TR><TD CLASS="quote">constant cell is usually a symptom of a bad ecu, try another ecu.</TD></TR></TABLE>
what he said
i ran my car soo messed up for so long, that it threw a bad ECU code, and i swapped ecu's fixed most of the problem, and put the ecu that was supposedly "bad" back in and it runs fine.
but a constat CEL is bad ECU
Chiovnidca Mar 6, 2006 01:13 PM
He's running Hondata though, so it could have other issues. Is the led in the interface box on solid or is it blinking?
THEUSED Mar 6, 2006 01:42 PM
Its blinking
THEUSED Mar 7, 2006 09:43 AM
Re: (THEUSED)
So I cut the jumper J1, and now my cel doesnt come on on my dash, but the box is still blinking, but it idles normally now and will rev to 6750, but vtec isnt working, rev limit is supposed to be at 9k
Chiovnidca Mar 7, 2006 01:54 PM
Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Its blinking</TD></TR></TABLE>
It should be on solid. I had 2 problems that caused it to blink: The first was the wrong version .bin burned on the chip and the other was a bad connection of the interface cable.
Chiovnidca Mar 7, 2006 01:55 PM
Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">So I cut the jumper J1, </TD></TR></TABLE>
Doesn't that jumper tell it which chip to run off of?
THEUSED Mar 7, 2006 07:15 PM
Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't that jumper tell it which chip to run off of?</TD></TR></TABLE>
Yea I did that to see if my ECU was bad but its not, and I double triple checked my cable and its good, so I guess my chips bad, but how does a chip just go bad?
aaronhume Mar 7, 2006 07:53 PM
Re: (THEUSED)
is it a stock ecu chip or something that was made for you?
THEUSED Mar 8, 2006 12:46 PM
Its my tuned Hondata map
Chiovnidca Mar 8, 2006 01:30 PM
Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Yea I did that to see if my ECU was bad but its not, and I double triple checked my cable and its good, so I guess my chips bad, but how does a chip just go bad?</TD></TR></TABLE>
You might find an answer on hondatas forum.
THEUSED Mar 15, 2006 01:19 PM
Re: (Chiovnidca)
The Hondata forums arent helping me too much http://images.honda-tech.com/set1//smile/emcrook.gif
I resoldered the connections; the Hondata eprom chip, 4 pin, and the SN74HC373N chip, but its still doing the same thing, what else could it be? I never took the chip out, so if it is the chip, then the chip just went bad while I was driving...
THEUSED Mar 31, 2006 12:52 PM
Re: (THEUSED)
Up cause I tried a new ecu and that didnt help at all.
dc-lefty Apr 9, 2006 04:15 PM
bump this. i have the same problem. CEL wont give me a code and the car cant rev past 4kprms. https://honda-tech.com/forums/images/smilies/emthup.gif
IndySporty Apr 11, 2006 10:08 PM
I got the same problem on a DA. Won't rev past 3k but runs normal otherwise. It's like the rev limiter is at 3k now.
dc-lefty Apr 13, 2006 01:32 PM
Re: (IndySporty)
no solution yet ???
THEUSED Apr 13, 2006 02:44 PM
Re: (dc-lefty)
No, but now my car is throwing cels that wont go away no matter what I do, and are random codes https://honda-tech.com/forums/images/smilies/emsad.gif
IMPORTMyth01 Apr 16, 2006 10:18 AM
bump same problem....im running a p74 ls-t in eg got it tuned and then now it wont rev over 4k
