Is this compression calculation correct?
I went to the C-speedracing.com website and used their compression calculator. This is what it gave me.
USDM B18B block (81.50 mm bore) B17A head Stock 3-layer head gasket Pistons: p73-A0 (USDM ITR) - 11.8 CR p73-00 (JDM ITR) - 12.4 CR pct (CTR) - 13.2 CR Are those correct? I just want to make sure before I go get a set of USDM ITR pistons for my LS/VTEC. What is needed to be done to the rods to make the pistons fit on Eagle B18B rods? |
Re: Is this compression calculation correct? (VTEC-DA)
Ok, I wa just reading thier LS/VTEC buildup and it says that they used the B17A head and the P73 pistons and that gave them a 10.9 CR. Whats going on here?
Bump, hopefully the real tech guys come out at night. https://honda-tech.com/forums/images...s/emsmilep.gif
I went to the C-speedracing.com website and used their compression calculator. This is what it gave me. USDM B18B block (81.50 mm bore) B17A head Stock 3-layer head gasket Pistons: p73-A0 (USDM ITR) - 11.8 CR p73-00 (JDM ITR) - 12.4 CR pct (CTR) - 13.2 CR Are those correct? I just want to make sure before I go get a set of USDM ITR pistons for my LS/VTEC. What is needed to be done to the rods to make the pistons fit on Eagle B18B rods? P73 (USDM)-10.904369584307167 : 1 C/R P73 (JDM)-11.42006109553134 : 1 C/R PCT-12.084251817988063 : 1 C/R Note: I used the piston to deck height of OEM B18A/B/C1/C5 - B20B/Z. |
Re: Is this compression calculation correct? (b19coupe)
Thanks alot. I must have just scrolled part that section. I thought my numbers were a little high.
| All times are GMT -8. The time now is 01:42 AM. |
