Common Honda Bolt thread pitch size dimension
Old 06-11-2008, 06:18 AM
  #101
B18EG6's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (Mcdc2)
which bolt for the mount?
Old 08-31-2008, 01:12 AM
  #102
monsterb18b's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (Bense)
95 civic coupe with LS motor. Please help. I been to dealership sites and its $8 a piece for the converter bolt (#4) that connects to the next exhuast pipe. The current bolt and nut are stripped. I need to cut them off. See picture:
What would be the correct size at some place like Lowes?
What are the sizes for the exhuast system?
Old 09-01-2008, 05:29 PM
  #103
B18EG6's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (monsterb18b)
I believe that one is an 8x1.25mm bolt... dunno the length though, may have to measure it and add ~20mm
Old 09-09-2008, 01:20 PM
  #104
dkrex001's Avatar
I got a 12x1.25 and it is not the 17mm bolts
Old 09-09-2008, 07:02 PM
  #105
B18EG6's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (dkrex001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">I got a 12x1.25 and it is not the 17mm bolts </TD></TR></TABLE>
a little background please - which bolt are you looking for?
some (maybe most) of the commercially available bolts are off by ~1mm compared to Honda... i.e., a 8 x1.25mm bolt from McMaster will have a head size of 13mm; not 12mm. (sometimes)
Old 09-24-2008, 01:33 PM
  #106
BB1 H22A LUDE's Avatar
Hey, does any one know the thread size of the oil filter's bolt in the rear of the H22A block? Thanks
Old 09-28-2008, 11:08 PM
  #107
Default Re: Common Honda Bolt thread pitch size dimension (BB1 H22A LUDE)
I found the size of it on a website, so for the record it has a M20 sized thread (connects to the oil filter). Now to fit my sandwich plate and oil pressure gauge....
Old 10-02-2008, 07:17 PM
  #108
JDM JEFFREY's Avatar
i need to know the thread pitch for a B series
fan switch
Old 10-02-2008, 07:45 PM
  #109
B18EG6's Avatar
Default Re: (JDM JEFFREY)
edit-
which one? the two pin one or the one pin one?
10 or 12?
Modified by B18EG6 at 6:34 PM 10/3/2008
Old 10-07-2008, 05:59 PM
  #110
Prudz_lude's Avatar
Default Re: (B18EG6)
BUMP!
Doing an engine bay shave and i want to clean it up with some finisher bolts/nuts. I need to know the following sizes
-UCA nuts
-Strut nuts
-Master cylinder nuts
-Fuel rail bolts
-Throttle body bolts
(sorry i know this is a bolt thread but i figured asking the sizes for some of the nuts would be okay)
These are all for H-Series
Old 10-08-2008, 05:38 AM
  #111
B18EG6's Avatar
Default Re: (Prudz_lude)
Here is a general rule for knowing the thread pitch for the bolt.
10mm head = 6x1.0mm bolt (or nut )
12mm head = 8x1.25mm bolt
14mm head = 10x1.25mm bolt
I'll get back to ya about the 17mm head suspension bolts
Old 10-08-2008, 09:11 AM
  #112
Prudz_lude's Avatar
Okay sweet! Thank you very much
Old 10-10-2008, 06:50 AM
  #113
crxmadness's Avatar
Modified by crxmadness at 5:09 PM 10/10/2008
Old 10-14-2008, 07:19 PM
  #114
tony413's Avatar
Default Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 &raquo;</TD></TR><TR><TD CLASS="quote">what bolts would i need to bolt on a b series tranny to the block? im taking a wild guess, is it a m14 x1.5 ?</TD></TR></TABLE>
i want to know the answer also
Old 10-15-2008, 08:30 PM
  #115
IN VTEC's Avatar
Default Re: (tony413)
Here's a random good one:
OEM oil cooler nipple into block coolant jacket- M16x1.50x~20mm
I'm having the hardest time finding a flange bolt locally to cap the hole.
Old 10-15-2008, 09:05 PM
  #116
tony413's Avatar
i found the answer to my questions in the tuck and shaved thread. i love them
Old 10-16-2008, 06:23 AM
  #117
B18EG6's Avatar
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Here's a random good one:
I'm having the hardest time finding a flange bolt locally to cap the hole.</TD></TR></TABLE>
There are a few on McMaster Pg 3099 "Metric Class 8.8 Zinc-Plated Steel Special Pitch"
P/N 91180A860 might suit your needs
Old 10-29-2008, 02:52 PM
  #118
HondatagirlPea's Avatar
Location: Between the hills of Downtown LA and Pasadena
Default Re: (allricedout)
anyone the the thread pitch for the 2 12 or 14 mm bolts on the head for the powersteering bracket?
i know its a m10 x40 just dont know the pitch.
TIA
Old 10-29-2008, 04:17 PM
  #119
IN VTEC's Avatar
Default Re: (HondatagirlPea)
1.25
Old 11-10-2008, 08:23 AM
  #120
Charlie Moua's Avatar
<FONT COLOR="red">
where can you by a tap (tapper? not sure what to call them)
I need M18x1.5 for the o2 bung
</FONT>
Old 11-10-2008, 09:52 AM
  #121
B18EG6's Avatar
Default Re: (Charlie Moua)
Originally Posted by Charlie Moua
<FONT COLOR="red">
</FONT>
McMaster has some, $36.24 each
P/N's
26015A281 (Taper)
26015A282 (Plug)
26015A283 (Bottoming)
Do you plan on tapping an unthreaded hole or chasing the threads on an existing O2 mount?
Seb
Old 11-10-2008, 10:06 AM
  #122
Seb
this is for stock y8 oem header
so i would be chasing correct?
Old 11-11-2008, 09:55 AM
  #123
B18EG6's Avatar
Correct I was going to comment that tapping a hole that large would require some tapping fluid or some other sort of lubricant. It would be a wise idea to use it to clean rusty threads also. Maybe just some penetrating fluid or wd-40 at the minimum.
Old 12-06-2008, 07:29 AM
  #124
used2bedomestic's Avatar
Bringing this one back from the dead....Hoping someone can help?
Need to know the thread pitch on the engine stiffener for an 92 Integra LS. It is the 17mm bolt that connects the stiffener to the transmission?
Any help would be great! Thanks.
Old 12-09-2008, 03:52 PM
  #125
DEIVIONCRX's Avatar
Anybody know the size and pitch of the Fuel Banjo bolt on the Fuel Filter.
Quick Reply: Common Honda Bolt thread pitch size dimension
