Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Cold NGK Plugs (https://honda-tech.com/forums/tech-misc-15/cold-ngk-plugs-124557/)
fastestdriver Feb 4, 2002 07:24 PM
Cold NGK Plugs
I am needing a set of plugs (preferably NGK) that are 2 or 3 heat ranges colder than stock. Where do I find them? What part numbers am I looking for? Thanks!!
bob01721 Feb 4, 2002 08:05 PM
Re: Cold NGK Plugs (fastestdriver)
You should be able to find NGK plugs just about anywhere.
Generally, the lower the number, the colder the plug, eg., a BP5ES is one range colder than a BP6ES.
PyroVTEC Feb 4, 2002 11:58 PM
Re: Cold NGK Plugs (bob01721)
Other way... 5 is hotter than 6...
On my turbo D16Y8, I'm running the NGK BCPR7ES plugs... two ranges colder. Mine's gapped to 0.031" but that's just mainly because of the stock ignition.
