Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   coilover adjustability ? (https://honda-tech.com/forums/tech-misc-15/coilover-adjustability-777608/)
wuclan Feb 23, 2004 06:18 PM
just a thought about height adjustment on coilovers. If i install coilovers set the hight to what i want i then need an alignment. My question is, if i decide to change the settings for whatever reason and then put them back to their original setting later will i need an alignment again? Also, assume i make these changes within a day or two not months.
wuclan Feb 23, 2004 08:23 PM
Re: coilover adjustability ? (joeegg)
anyone?
miguel6632 Feb 23, 2004 08:34 PM
u guessed it yes youll need an aligment but it isnt that bad ..remember chamber doest eat tires toe in or out does
wuclan Feb 23, 2004 09:48 PM
Re: (miguel6632)
thanks for answering
suspendedHatch Feb 24, 2004 10:51 AM
Re: (joeegg)
Let me see if I understand your question. You set all four coilovers to point A, mark them, then get an alignment. Then you tweak the settings to point B w/out getting an alignment. Later you put them back exactly to point A.
No you will not need another alignment.
In fact, you can have the toe adjustment marked at point A, get another alignment at point B and mark the toe adjusters with a different color,and then you'll be able to switch back and forth. A can be your street ride height and alignment, and B can be your track ride height and alignment.
FR-MOB: ThE bEe GuY Feb 24, 2004 10:59 AM
Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">Let me see if I understand your question. You set all four coilovers to point A, mark them, then get an alignment. Then you tweak the settings to point B w/out getting an alignment. Later you put them back exactly to point A.
In fact, you can have the toe adjustment marked at point A, get another alignment at point B and mark the toe adjusters with a different color,and then you'll be able to switch back and forth. A can be your street ride height and alignment, and B can be your track ride height and alignment.</TD></TR></TABLE>
... thats a friggin good idea! I wish i thought of that when i had my crx https://honda-tech.com/forums/images/smilies/emsad.gif Same thing if you have a camber kit, you can just mark where it is and readjust it.
rapid_roy Feb 24, 2004 12:07 PM
What you should do is set your height so that you get the camber setting you desire, have it aligned and never touch it again.
Cheers,
Sean
