Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   code 43 still persists: any ideas? (https://honda-tech.com/forums/tech-misc-15/code-43-still-persists-any-ideas-663512/)
specie Oct 29, 2003 11:05 PM
vehicle: '95 LS
I've been trying to deal with a code 43 for the longest time. It's a fuel system problem. I've replaced the 02 (3 times), the fpr, injectors, fuel filter, and now have a walbro pump. An ecu is next on the list. The problem started after I removed my air bag; might just be a coincidence.
I've noticed that after I shut off the car, the fp drops to zero w/i a couple seconds. I believe fuel pressure should stay up for a little while. My fp guage shows around 42psi when the engine is running. I have no clue what the problem might be. Anyone have pictures around the fuel filter area. I just wanted to make sure that nothing is missing that's causing the problem. Thanks.
specie Oct 31, 2003 10:56 AM
Re: code 43 still persists: any ideas? (specie)
anyone have pics near their fuel filter?
b20turbojason Oct 31, 2003 11:50 AM
just an idea but if you are dropping pressure think may it could be fpr. i don't know how they act when they go bad but. i have noticed that they do go pretty often.
specie Nov 1, 2003 11:23 AM
Re: code 43 still persists: any ideas? (b20turbojason)
I've changed the fpr already, but I still have the same problem.
