Code 20. ELD(electronic load detector) ?????
Already did a search.
Put an LS in a crx. still OBD0. Car wont start. Battery is good. Could it be a bad starter or alternator? when im trying to start the car, lights go dim and car almost dies. anyone know a solution? any help would be great. thanks guys |
does it crank?
check ur ground the main ground is from the tranny to the body by the battery tray |
Re: (rev-speed)
its good, it cranks. but when i keep cranking it, it gets weaker and the lights dim.
u can either hook up a vat 40 and measure how much current ur starter is drawing
or throw a jumper cable to it with another car |
Re: (rev-speed)
ill try that. thanks
| All times are GMT -8. The time now is 05:18 AM. |
