Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Clutch Problems (https://honda-tech.com/forums/tech-misc-15/clutch-problems-1158424/)
yellowctr97 Feb 22, 2005 04:20 PM
Clutch Problems
I just reciently put in a stock clutch in my B18C.. i normally rev it to about 8.5...the other day i had it pinned to 8.5 and it reved to 8.7 and it sliped off...anyone have any ideas of what is the problem...maybe to much on the clutch being that its stock?
dunkd Feb 22, 2005 06:12 PM
did u break in the clutch? (if it was new)
neogenesis2004 Feb 22, 2005 08:59 PM
Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">did u break in the clutch? (if it was new)</TD></TR></TABLE>
in addition to that, did you resurface the flywheel?
yellowctr97 Feb 23, 2005 11:08 AM
Re: (neogenesis2004)
what is breaking in the clutch?...i mean its been a good month or two...and no i didn't resurface the flywheel could that be one reason?
neogenesis2004 Feb 23, 2005 12:03 PM
Re: (yellowctr97)
not resurfacing could definately be a problem. Breaking in the clutch is just driving easy on it for a good 500 miles before taking it over 4-5k rpms. Also no clutch dumps either. The reason you need to resurface is because the flywheel is worn to the old clutch disc. You need to resurface to make it able to wear to the new one.
yellowctr97 Feb 23, 2005 03:39 PM
alright thanks i'll take and get it resurfaced asap...i mean it is a stock clutch from advanced hopefully resurfacing will eliminate the slipping
neogenesis2004 Feb 23, 2005 04:22 PM
Re: (yellowctr97)
just make sure you drive easy on it for a couple tanks of gas. shift at around 3-3.5k
