Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Check engine Light on. PLZ help (https://honda-tech.com/forums/tech-misc-15/check-engine-light-plz-help-787469/)
Awax223 Mar 3, 2004 03:46 PM
Well my check engine light came on yesterday so i took it to auto zone to get it hooked up to a cpu to find the problem. This is what they told me to write down and show it to someone at the Honda dealership:
P1259
Immobilizer to PCM Signal error
Does anyone know what this means?
Awax223 Mar 3, 2004 05:50 PM
Re: Check engine Light on. PLZ help (Awax223)
ttt
poison Mar 3, 2004 06:43 PM
wtf? did they give you a code number?
describe your car too. info info..
Turbogixxer Mar 3, 2004 07:21 PM
Re: Check engine Light on. PLZ help (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">wtf? did they give you a code number?
describe your car too. info info..</TD></TR></TABLE>
It looks like from a scanner and OBD2
Awax223 Mar 3, 2004 07:28 PM
o sry my car is a 97 EX and it is all stock.
poison Mar 3, 2004 07:49 PM
Did they give u a code number at all? Should be a 1 or 2 digit code
Awax223 Mar 3, 2004 08:17 PM
nope just this P1259.
kwil6666 Mar 4, 2004 12:43 AM
P1259
that is the code, thats what the code looks like when its from a scanner. if you look inside a manual it will say the codes and what they mean. sorry i cant be much more help im at work and dont have any info here.
keith
EE_Chris Mar 4, 2004 05:26 AM
Re: Check engine Light on. PLZ help (kwil6666)
Just to clear it up: "P" codes are specific to OBD2...and "P1" indicates a manufacturer specific code.
And you have a totally stock 97 Ex....I thought only Teg's came equipped with immobilizers???
Awax223 Mar 4, 2004 05:31 PM
Re: Check engine Light on. PLZ help (EE_Chris)
Hmmm that is weird? I bought the car from some mom and pop dealership for 3k, so maybe the did some shit to the car? https://honda-tech.com/forums/images...es/emdgust.gif
Chiovnidca Mar 4, 2004 06:34 PM
p1259 = VTEC system malfunction
Awax223 Mar 4, 2004 06:49 PM
Re: Check engine Light on. PLZ help (Chiovnidca)
cool Thanks! what do i have to do to fix it? DO i need to buy a new Manifold?
poison Mar 4, 2004 07:02 PM
No, sounds like the vtec solenoid is either not connected, or is a bad solenoid.
Jump the solenoid by taking a piece of wire and putting 12v volt to the solenoid. It should click. If it does, you have a wiring problem or bad connection. If it doesn't click, then the solenoid will need to be replaced.
Awax223 Mar 4, 2004 07:07 PM
cool Thanks a lot guys! Is there a write up anywhere for this i can look at by any chance?
poison Mar 4, 2004 08:11 PM
A Helms manual will explain troubleshooting. https://honda-tech.com/forums/images...es/emsmile.gif Other than that, it's cake.
Awax223 Mar 5, 2004 07:53 PM
Thanks for the info again fellas. I tested and cleaned the solenoid and now my CEL is off and my Vtec is back! https://honda-tech.com/forums/images/smilies/emthup.gif
