check engine light off
01 civic salvage
check engine lite is off,run normal check ground and power to light buld okay wat could it be? wrong guage? |
Re: check engine light off (im_the_teacher)
hugh?
whatz your problem ?
Re: check engine light off (Bspec18)
you know the check engine light?
it won't come on......usually it should come on when u key on.....for 5 sec.... is on 01 civic |
did you check the bulb?
Look for the service pin connector and jump it. If it doesn't light on bad bulb.
| All times are GMT -8. The time now is 02:37 AM. |
