Check Engine light not working/turning on, turn signals not working, tach not working
1994 acura integra ls automatic. wth is going on? please help
Re: Check Engine light not working/turning on, turn signals not working, tach not wor
Have you checked all your fuses?
Does car run? Do the hazard lights work? 94 |
yup hazard works. car runs and drives. tach, check engine light not turning on and i tried both ls and gsr clusters. gonna pull every fuse individually tomorrow to check.
Did this just start or did you get the car like this?
i bought the car like this. havent had the time to check fuses yet but thanks for the fuse diagram and tips. will get back to you guys when i check.
pulled and checked all fuse. all are good. no turn signals and no check engine light turning on or off. checked bulb and works
Originally Posted by dc2b20vtec
(Post 46738777)
nevermind. found out i left one of the plugs loose when i took out the fuse block to replace icu. was chasing my tail for days. i forgot to do the number 1 thing: Check the basics
