Check engine light
I have a 98 Integra (LS) and I was just driving down the highway and my check engine light came on. What does this mean? What should i do? Thanks for the help.
Re: Check engine light (Slow)
Autozone will check it for free and tell you what the code is.
actually, i dont think autozone can do it anymore.... you'll have to check it yourself and then look it up. got repair manual?
You probably need to bring it into the dealer to have them check it out.. There is a place where you can reset the light off but without the dealer doing the right code or whatevers.. it will just come back on in a few days.. atleast this is what i have been told by a few people....
If you don't know and don't have a friend who does, then chances are that you will need to pay somebody to check it for you. To pull the code, there is a two pin blue connector on the right side of your car, underneath the glovebox. Turn the key on and jump the connector. Your check engine light will flash; long flashes = tens, short flashes = ones.
Honda ECU Trouble Codes -------------------------------------------------------------------------------- ( 1) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor (2) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B" defective circuit or unplugged / defective sensor (3) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor (4) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor (5) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping * exc 94-95 (6) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor (7) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor (8) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor (9*) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor * not a valid code for any throttle body injection Hondas ** not a valid code for V-6 engines (10) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor (12) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor * not a valid code if car is not equipped with an EGR valve (some Civic models are not) (13) Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor (14) Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor (15) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal missing or defective ignition output signal (16) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System defective circuit or unplugged / defective fuel injector (17) Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor (19) Accord Civic CRV CRX Del Sol Odyssey Prelude n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve (20) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector defective circuit or unplugged / defective sensor (21*) Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve * not a valid code if car does not have a VTEC engine ** not with V-6 engine (22*) Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch * not a valid code if car does not have a VTEC engine (23) Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor) defective circuit or unplugged / defective sensor * not a valid code if V-6 engine (30) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor * not a valid code for 1996 (31) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor (41) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater circuit malfunction (43) Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System defective or malfunctioning fuel supply system (45) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich malfunction in the fuel monitoring systems (48) Accord Civic CRV CRX Del Sol Odyssey Prelude 98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor (54) Accord Civic CRV CRX Del Sol Odyssey Prelude 96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor (58) Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center) defective circuit or unplugged / defective sensor * with V-6 engine only (61) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response (63) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response (65) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater (67) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system (70) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission malfunction with the automatic transmission controls (71) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire (72) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire (73) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire (74) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire (75) Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only (76) Accord Civic CRV CRX Del Sol Odyssey Prelude 98* n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only (80) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation insufficient flow detected (86) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem (90) Accord Civic CRV CRX Del Sol Odyssey Prelude 97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System leak detected in the fuel tank area (91) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor low input (92) Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System insufficient purge flow These same codes apply to Acura vehicles. [Modified by b19coupe, 1:56 AM 11/17/2002] |
id say pull the code with the paper clip trick and then youll have something to go on, dont take it to the dealer and get raped!!
I checked and I got code #90 (Accord Civic CRV CRX Del Sol Odyssey Prelude 97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System leak detected in the fuel tank area) So, I unplugged the battery and the check engine light went away for about 2 days. It has now come back on. What does this mean? Thanks for your help.
If your gas cap is tight, it means you probably have a leak in the evap. system. These are not fun to troubleshoot, so you may want to enlist some professional help.
any other ideas?
Your problem may be covered under your Acura emissions warranty.
Thanks
I work at a Honda dealership and almost everytime we get an evap leak code, it is either the evap canister or the bypass solenoid. I don't know if this would apply to a teg. http://rely.net/~htimages/smile/h-emblem4.gif http://rely.net/~htimages/smile/emthup.gif http://rely.net/~htimages/smile/acura1.gif ?
go to any mechanic and ask them to scan your car because your check engine light is on. all they do is hook a scanner to your car and it spits out a code(s). and tells you what your problem is. there may be more than 1 code but you fix the first one that pops up. because it could be related to the second problem and so on. the problem could be as simple as a loose vacuum hose. hope that helps
| All times are GMT -8. The time now is 03:12 PM. |
