Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Check Engine Light (https://honda-tech.com/forums/tech-misc-15/check-engine-light-2233898/)
accord20o1 Feb 24, 2008 05:23 PM
How to check CEL OBD2 to OBD1
i was wondering how do you check the CEL on the car if you are using the OBD2b to OBD1 harness? do you need to splice the harness and jump it like that?
accord20o1 Feb 24, 2008 10:04 PM
anyone?? because i know you cant use the obd2 scanner once you go obd1 right?
inspyral Feb 24, 2008 11:21 PM
Here's a good illustrated guide to retrieving trouble codes without a scanner:
http://www.c-speedracing.com/faq/06.php
This is a list of trouble codes:
http://www.c-speedracing.com/faq/05.php
Modified by inspyral at 12:42 AM 2/25/2008
accord20o1 Feb 25, 2008 09:05 AM
only OBD1 cars have that no?
inspyral Feb 25, 2008 11:48 AM
Re: (accord20o1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord20o1 &raquo;</TD></TR><TR><TD CLASS="quote">only OBD1 cars have that no? </TD></TR></TABLE>
My car, and every other OBD-II Honda I've seen has it.
accord20o1 Feb 26, 2008 01:24 PM
thats weird.. i have an 2001 accord i4 and its not there
inspyral Feb 26, 2008 02:22 PM
It's usually tucked behind the kick panel or up under the dash a little, usually in a green rubber holder.
accord20o1 Feb 28, 2008 09:57 AM
i guess they dont have it on a 6th gen accord... i pulled off everything... i know ive seen it on civic and integra but its not on my car.. i had to jump it from the harness...
HONDAPARTSMANMIKE Feb 28, 2008 04:05 PM
Re: How to check CEL OBD2 to OBD1 (accord20o1)
What year is the car? you should have the two wire connector that you can jump some were around the pass. side kick panel area.
accord20o1 Feb 29, 2008 12:16 AM
2001 honda accord... i pulled off everything...
