changing head gasket
whats the average cost for a 96 integra rs. thx
Re: changing head gasket (quikrpm1)
Thirty to sixty dollors would be your range. I would recommend a high compression head gasket, since you are already going in there, might as well go performance. Thats what I am doing, I think I will choose copper...
Get the head milled to raise the compression. It's already off the car so why not?
Re: changing head gasket (ctiburcio)
dont really need higher compression, im looking for something reliable. (turbo under the hood)
i don't think they make it for a ls but check out a hks lower 5 layer head gasket should lower your commpression nicelly. if you can't find a GOOD 4-5 layer head gasket then just get oem honda no discount auto stuff. And hay if you want to be creativr(possibly blow your hed gasket ) try using 2 stock 3 layer head gaskets.hehehe
| All times are GMT -8. The time now is 07:33 AM. |
