Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Changing antifreeze (https://honda-tech.com/forums/tech-misc-15/changing-antifreeze-221308/)
mikefm58 Jul 2, 2002 02:36 PM
Changing antifreeze
I need to change my anti-freeze and the owner's manual says to "remove the drain bolt from the cylinder block". Where is this located? How much anti-freeze will I leave in if I don't remove the drain bolt? I have a '99 CRV.
Spade Jul 2, 2002 03:14 PM
Re: Changing antifreeze (mikefm58)
Drain bolt located by the Engine Id number.
mikefm58 Jul 2, 2002 05:32 PM
Re: Changing antifreeze (Spade)
Thanks for the suggestion, but you're not talking to an expert mechanic here. I don't know where the engine id is located. How much anit-freeze will drain out after removing this bolt?
ALF Jul 2, 2002 07:10 PM
See if it's here:
http://www.bseries.net/images/garage...ermostat03.jpg
Mike P. Jul 2, 2002 08:50 PM
Re: Changing antifreeze (ALF)
that's the one. Make sure it's cool, because you'll burn your hands as that stuff comes gushing out.
mikefm58 Jul 3, 2002 03:47 AM
Great pic ALF, thanks, even I can find that. How much anti-freeze will drain out of the engine when I remove the drain bolt?
