Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   cel code 43 (https://honda-tech.com/forums/tech-misc-15/cel-code-43-a-1764681/)
92GSR HB Sep 27, 2006 12:11 PM
cel code 43
My car recently has been throwing Cel 1 and 43. im more concerned with the 43 than anything. im going to pull the injectors and soak them in cleaner to see if that might be the problem. btw my car has a new fuel filter. anybody got other suggestion to what might be causing this?
slomofo Sep 27, 2006 12:44 PM
Do you have any vaccuum leaks? Is your FPR adjustable?
civickiller Sep 27, 2006 12:46 PM
Re: cel code 43 (92GSR HB)
sometimes a bad o2 will cause a code 43, i believe
92GSR HB Sep 27, 2006 12:49 PM
it is throwing a code 1 which is O2, but that sensor is relatively new. No i just have a FP Gauge thats it. My car sometime tends to start then die like its not gettin gas, but usually starts the next try or so.
slomofo Sep 27, 2006 01:54 PM
Test the fuel pressure, it could be your FPR or maybe your pump.
92GSR HB Sep 27, 2006 07:02 PM
my fp gauge has been reading different numbers lately, usually a 5-10 psi difference at idle. im cleanin the injectors tomarrow, if continues ill look into investing into a wally pump. i wished i had a wideband grr
imjustakid Oct 5, 2006 11:48 PM
check the voltage on the connectors sometime they don't spray enough fuel due to lack of voltage
