Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Car Safe to Break In?? (https://honda-tech.com/forums/tech-misc-15/car-safe-break-1058847/)
1BadCvC Nov 17, 2004 10:10 AM
Instead of breaking my motor in on the dyno im gonna put 700 or so mi. on it then tune it. The setup is a b18c bored to 85mm with JE 12:1 pistons, i have cam gears and a FPR along with a EGT gauge to keep a close eye on the A/F. Im wonding if it would be possible to perform a safe break-in along with being descently tuned? thanks
drdisco69 Nov 17, 2004 10:36 AM
Re: Car Safe to Break In?? (1BadCvC)
Meh, the egt can only do so much in keeping track of AF ratios. It's possible, just back off the timing and be a little generous with the fuel, but why are you breaking it in on the street and not on the dyno? If you're going there anyway, it's the pefect time to do it.
1BadCvC Nov 17, 2004 10:45 AM
Re: Car Safe to Break In?? (drdisco69)
idk, guess bc ive had so many problems. im weary of the high rpms that it would have to run at on the dyno.
drdisco69 Nov 17, 2004 11:03 AM
It's either going to break or it's not. Waiting isn't going to make it any stronger at high rpms. To get the rings to seal, you need to generate cylinder pressure, and the best way to do that in a controlled manner is a dyno. And the same procedure you use to break it in is the way you tune it:
50% throttle through 50% rpm range
60% through 60% rpms
70% through 70%
continue until you are at 100% throttle to redline. All this time you are watching AF and EGT and tuning as needed. This procedure also puts a load on the rings and breaks them in, ensuring a good seal and reducing blowby.
1BadCvC Nov 17, 2004 11:10 AM
Alright you talked me into it https://honda-tech.com/forums/images/smilies/emwink.gif Thats the break-in im goin with anyhow so may as well do it on the dyno. ill just make sure it starts up fine b4 i haul it out of town...all or nothin i guess, thanks for the advice.
