Car Over-fueling After Fuel Line Came Loose - *Solved*
Old 01-16-2019, 07:01 PM
TypeC's Avatar
Default Car Over-fueling After Fuel Line Came Loose - *Solved*
Setup: 9th gen Si, turbo kit, ID injectors, e85, FlashPro/stock ECU (car has run flawlessly)
  • When installing my Dakota Digital box, I removed the fuel line from my flex fuel sensor but apparently didn't put it on fully (didn't snap-in). Drove the car for several miles just fine (even a quick WOT pull which had perfect fueling). A mile from home the car started sputtering horribly, and I limped it home (~1/2 mile). My fuel connection is located above my air filter and beside my ECU.
  • I found that the fuel line had come off, so I reconnected it. Car wouldn't start.
  • I removed spark plugs, let everything dry overnight, and the car started.
  • Car runs SUPER rich - I had to remove 30% fuel just to get it to have normal fuel trims (otherwise it is sub 10:1 even at idle)
Things I've tried (with no result):
  • Unplugged battery
  • Re-flashed ECU (with same map)
  • New MAF (thinking old one got e85 on it as filter got very wet)
  • Swapped injectors (ID1700 first, then ID1300 next both with proven/solid maps that I ran recently)
  • Compression test (180-185 across the board)
  • Adjust fuel scaling in ECU (I have to remove 30%, which is nuts and even then the car tries to over-fuel once it has been driven a little)
  • Unplug flex fuel connector (this has the same effect of removing 30% fuel, as that's what in the table for my ethanol content)
At this point, I'm almost out of ideas.
Only things I can think of:
  • ECU was shorted somehow, perhaps via the flex fuel connector (ELD2 on ECU), or any connector as fuel was gushing
  • Swap & reprogram new ECU
  • Somehow there is fuel pooled in my FMIC (long shot?)
Any ideas or long shots welcome. I'm stumped.
Thanks,
-C
TypeC is offline
Old 01-21-2019, 06:32 PM
TypeC's Avatar
Default re: Car Over-fueling After Fuel Line Came Loose - *Solved*
---Solved---
To follow my hunch, removed FMIC and found a TON of gas trapped inside. This explains the over-fueling and how it wasn't consistent (more airflow caused even higher fueling). Thankfully there are several humps/loops in the IC piping, otherwise hydrolock would have been a certainty!
TypeC is offline
Old 01-21-2019, 06:47 PM
K7-1Ktrevor's Avatar
Right on. Glad you got it fixed and reported the solution. Definitely wouldn't have thought that the intercooler being flooded would have been the issue.
K7-1Ktrevor is offline
TypeC
Honda Civic (2006 - 2015)
01-16-2019 06:56 PM
eriki
04-06-2013 07:53 PM
underb00steg6
10-30-2007 02:29 AM
queensny
05-07-2004 01:13 PM
Quick Reply: Car Over-fueling After Fuel Line Came Loose - *Solved*
