car almost hit the wall coming out of a car wash
car rolled to the left side because of the roller in the car wash when it was coming out why did this happen? I looked like a bikini model with my hands spread across the hood at the car wash trying to stop the car from hitting the wall thankfully bystanders helped...car is an automatic eg hatch
Re: car almost hit the wall coming out of a car wash
I think you are supposed to remain in the car while it gets washed. Apply brake or turn so you don't hit the wall.
I had a 1998 toyota camry that i would take to the same car wash and it would just roll straight out with nobody in it why doesn't my honda do the same?
Somethings out of wack. Maybe a brake caliper is sticking on one side and the wheel doesn't spin as freely. I would jack up the front end and see if both front wheels spin the same. If one does not then I would investigate more and try to figure out why.
Why were you not in the car when it was being washed ? Car should be stopped and ebrake applied. Something in your story isn't adding up.
you right
it was in neutral
half of the above replies are jokes, just fyi.
I too and wondering though why nobody was in the car. some car washes require the car to be in neutral, some require the ebrake on and brakes held. but there should still be someone in the car
97akwerd
08-05-2005 02:42 AM
