Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Which cable tranny is best? (https://honda-tech.com/forums/tech-misc-15/cable-tranny-best-165513/)
Hayasa15 Apr 15, 2002 07:00 PM
I am getting ready to swap a b16 into my civic. I am having a hard time finding information on the cable trannys. Which is best for the b16? What is the difference between the s1, y1, ys1...?
rainforest Apr 15, 2002 07:35 PM
Re: Which cable tranny is best? (Hayasa15)
s1 w/lsd. same gearing as a usdm type r but has bad 3rd gear syncro.
y1 4.2 final longer than the s1 but stronger.
ys1 92-93 gsr tranny same gearing as s1 and strong as the y1.
Hayasa15 Apr 15, 2002 07:56 PM
Re: Which cable tranny is best? (rainforest)
So would you suggest the ys1 for a b16? Also it is my understanding that the ys1 would be better because you can kit parts for it easier? Correct me if i am wrong.
rainforest Apr 15, 2002 08:01 PM
your right.
Hayasa15 Apr 15, 2002 08:02 PM
What can you tell me about the j1?
fire7882 Apr 16, 2002 02:39 PM
I think it is the same as the s1 but with a different final drive ratio.
g's integ Apr 17, 2002 02:59 PM
yeah, I'm about to swap my '95 LS w/ b18c which has a b16 head. Which cable tranny should I go. Can't really afford a hydro tranny right now. This guy is selling a j1 off 91 b16a for $350. What do you think guys?
bryant Apr 17, 2002 03:39 PM
Re: Which cable tranny is best? (g'sinteg)
J1 and S1 are the same thing, but i think J1's are a bit stonger. But both have the same Gear ratio. YS1 w/LSD or a J1 w/aftermarket LSD would be best. IMO
2K_TEG Apr 17, 2002 03:56 PM
Re: Which cable tranny is best? (CR-X)
Sorry for the newbie question, I don't know shit about trannies. What is the difference btwn hydro and cable? Which came stock with which cars?
bryant Apr 17, 2002 04:50 PM
Re: Which cable tranny is best? (2K_TEG)
Cable clutches came in the earlyer years (??-91) They use a cable to engage and disengage the clutch. They usually wear faster then the hydro clutches.
Hydrolic cluthes came in the later years. (92-Present) Im not real sure on exacly how they work. So i dont want to give you any wrong information. But they do last longer than the cable clutches
Also a cable type tranny is cheaper then a hydro tranny. $$$ wise.
[Modified by CR-X, 7:51 PM 4/17/2002]
2K_TEG Apr 17, 2002 05:15 PM
Thanks
fire7882 Apr 17, 2002 05:33 PM
hydro tranny works similar to the way your brakes work. A hydrolic fluid is used to move a piston of some sort, whish in turn moves the clutch fork that engages the clutch. Hope that helps
