Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Bypassing map sensor !!! (https://honda-tech.com/forums/tech-misc-15/bypassing-map-sensor-2599245/)
cleanazcoupe Jun 30, 2009 10:21 PM
is there anyway to rewire map sensor so my car can get out of limp mode???
Utzz Jul 1, 2009 06:22 AM
Re: Bypassing map sensor !!!
The MAP sensor and RPM are the two inputs that the ECU uses to look up a base value for fuel injection and spark. You don't want to bypass the MAP sensor.
wc4123 Jul 1, 2009 07:53 PM
a defective oxygen sensor would keep the ecu in limp mode. you don't want to bypass it. replace it.
