broken lug wtf?
ok, i went to take the wheel off the front passenger side of the car, and the dang lug broke of in the nut, what the hell am i supposed to do about this, i need your help quick.
Re: broken lug wtf? (extrmeboost)
take the broken stud out (is it in the front or rear)if its the front you have to take the axel out of the hub and pull the hub off because of clearence problem.thats if u have a teg,i dont know about eg's ,ek's,ef's
Re: broken lug wtf? (Cro-Mag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cro-Mag »</TD></TR><TR><TD CLASS="quote">take the broken stud out (is it in the front or rear)if its the front you have to take the axel out of the hub and pull the hub off because of clearence problem.thats if u have a teg,i dont know about eg's ,ek's,ef's
</TD></TR></TABLE> Like he said, just replace the broken one and you'll be fine, no big problem. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: broken lug wtf? (Prelude Vtec 23)
but is it ok to drive until then, its the front passenger hub on a 00 civic ex
yes, make sure the other 3 is tightened but make sure you get it done ASAP.
Someone once stole 1 lug nut from all 4 wheels and I drove around for at least a week without noticing, I guess he really needed it. I am just glad he didn't take them all from one wheel |
Re: broken lug wtf? (Loveless)
You should be fine to drive but that isnt something you just let go and dont try to fix asap.
| All times are GMT -8. The time now is 07:13 AM. |
