Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   brakes? (https://honda-tech.com/forums/tech-misc-15/brakes-1741967/)
DARKTEG_ Sep 4, 2006 08:43 AM
brakes?
ok...i'm puttin on an aem big rotor kit...i've heard that you have to put new pads on at the same time... is that true?
-Championship- Sep 8, 2006 02:05 PM
Re: brakes? (gonk_1)
is this guy for real, is this funny just for me or is people actually getting a kick out of it
ok man just use the same brake pads, it will be OK
iH8RICERZ Sep 8, 2006 02:23 PM
Re: brakes? (CW_98gsr)
it would be "OK" but its not recommended. Try searching AEM's website or talk to their customer service reps and find out what you need to do the install.
MR_FIX_IT Sep 10, 2006 03:46 AM
Re: brakes? (DARKTEG_)
its bettert to change the pads at the same time. Brake pads will create a wear pattern. If the rotors u had previously had any kind of groves or wear marks, u would have the same groves and wear marks on that corresponding pad. Now what happens is, when u take that pad off, and use it with ur new rotor it will transfer those groves and wear marks from ur pad onto ur new rotor. It will trash a new rotor, especially if they are ceramic pads. If ur going to spend good money on rotors, u might as well spend sum on pads too.
DARKTEG_ Sep 10, 2006 03:59 AM
Re: brakes? (DA_integra_Dude)
the rotors are used too, off my friends car...
dwn2earth922 Sep 10, 2006 03:45 PM
Resurface + new pads...
MR_FIX_IT Sep 11, 2006 11:53 AM
yea, i would just have ur rotors turned, and get new pads.........................r they slotted or drilled.................if so i would get a set of ceramic pads.
DARKTEG_ Sep 11, 2006 01:38 PM
aem slotted, the thing is i have ebc green stuff pads that are only 6 months old, and they're not cheap, and front rotors are mildly warped...
MR_FIX_IT Sep 11, 2006 09:02 PM
i know how pricy those pads r, i think it would be safe to say, go ahead and use those pads and when it comes time to replace them, have ur rotors turned at that time.
DARKTEG_ Sep 12, 2006 02:07 PM
i heard if you have warped rotors turned... that they warp back twice as fast and turn out twice as bad... is this true?
95IRS Sep 12, 2006 06:00 PM
Re: brakes? (iH8RICERZ)
you'll be alright if you decide to use old brake pads but you'll be better of spending the extra $200 on good brake pads. Reasons are is because you would rather have the pads and the rotors work in evenly
Recommed pads AXISS i believe thats what there called just installed them on my rotora slotted disk a day or 2 ago and they work wonderss
