Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   brake disc (https://honda-tech.com/forums/tech-misc-15/brake-disc-1895125/)
CrX-WoRlD Feb 14, 2007 05:31 PM
brake disc
how to remove the 2 bolts that hold the brake rotors?.....thy are stuck there!!! https://honda-tech.com/forums/images/smilies/emsad.gif
4WSi_guy Feb 16, 2007 12:17 PM
Re: brake disc (CrX-WoRlD)
I assume you mean the phillips head screws? Drill the heads off...once you get them drilled the rotor will come off...then use a pair of vise grips to get the rest of them out...you dont have to put new ones back on if you dont want to...the wheel holds the rotor on...they just help with brake chatter...but you can get new ones at the dealership. I tried to use a impact screw driver once...even that didnt work. I've drilled these on all my cars. GL https://honda-tech.com/forums/images/smilies/emthup.gif
PHDZINE Feb 16, 2007 03:44 PM
Impact screw driver...but only if you haven't already stripped the screw!
b16nonoy Feb 17, 2007 03:18 PM
impact screw drive and a 2lbs sledge hammer...if you stripped the phillips pattern already...your gonna have to drill them out..
Surfjunkie44 Feb 18, 2007 01:55 AM
Re: brake disc (b16nonoy)
Done on at least three or four cars... it's just the way it goes with Hondas. For everything else we get out of them I'd say it is worth that lil' headache...
