Blox Adjustable Testpipe Minimum Length?
Hello All,
I am about to buy a Blox 2.5" adjustable length testpipe, but I want to make sure it will work for my application. The stock cat it will be replacing is exactly 14.5" in length. I need to make sure the Blox testpipe is adjustable down to this length. I am too impatient to wait until tomorrow morning to call a shop and have them measure, so if anyone out there knows, please let me know. Thanks! -Jason |
Re: Blox Adjustable Testpipe Minimum Length?
Would also like to know the minimum and maximum lengths?
Thanks |
I don't understand the need for an adjustable length straight pipe. Just stop by a local exhaust shop and have them cut some extra pipe to the needed length, weld on the flanges, and be done with it.
Originally Posted by TunerN00b
(Post 41684461)
Or try the Omni test pipe. It comes as a three peice and you can take out the middle section if you dont need it. On mine with a JDM 4-1 header i only used the two end peices.
| All times are GMT -8. The time now is 06:28 AM. |
