Coil on plug setups - do I really need one in my case?
Hello I had a question on the coil on plug kits that are out I looked at Hondata witch would work with my s300 but also looked at the AEM but I read its only good up to 15 psi of boost my question is what company is best for my build or other companies to check out thanks
Moderator
re: Coil on plug setups - do I really need one in my case?
Get your setup together first, show us in detail, then you can discuss whatever or not you need COP.
Re: Coil on plug setups - do I really need one in my case?
In my opinion, what you should be evaluating, is the turns-ratio of the coil that is firing the plug, and whether or not the voltage produced can close the gap (IE spark the gap). The more cylinder pressure you have (along with combustibles in the chamber) the heavier duty (higher turns ratio) of a coil you will need to ensure it will spark. This is why the plug gap on most turbo cars is so small: Using a stock coil may not produce a high enough of a voltage to close the gap, resulting in a misfire unless the plug gap is closed.
In most of these cases, people choose to close the plug gap to ensure the spark event occurs because it is easiest. You could also get a more powerful coil (higher turns-ratio/current rating) and achieve the same result with a bigger plug gap. The best advantage is having the largest plug gap possible, with the most powerful coil. Remember, coils do no make horsepower, they are needed to facilitate it!
Thanks I have everything together already full gsr sleeved block 8-5to1 comp built head 2000 cc injectors reason I ask the coil in my stock dizz went out instead of buying new might up grade to coil on plug also running 6262 turbo 3 inch pipe
hondatech8798
Engine Management and Tuning
10-27-2012 01:32 PM
patroick67
04-11-2012 08:28 AM
JDMlyfestyle
03-23-2006 05:44 PM
